How about hooking the lights up in pairs wit two switches (and relay).
That way you can turn on two at a time or if one set goes out then you still have one set to work with.
How do you intend to do the wiring, relays, direct to the battery, don't forget to get a good ground ?
Just a note, the bumper is a poor grounding location, run a heavy gauge ground wire back to the battery, all four can be on the same 10-ga wire but two 12-ga wires keep thing separate...
