AgPete139
09/2014 OTOTM Winner
⭐Supporting Member
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
- Aug 12, 2007
- Houston, TX
- 4.0 V6
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
Hey Guys,
I bought a brand new Super Pro 3" tach from a guy on Craigslist for $15 last week.
No cut wires, or tampering, but it does have a small external scratch from storage.
So here I am. I took the tach apart and switched it for 6 cylinder engines. I spliced the GREEN WIRE into what I believe is Pin 48 on the passenger side firewall for my '97 4.0L w/ the 5R55E. It was BROWN w/ YELLOW stripe, and I never saw a TAN w/ YELLOW stripe in the cluster. I roughly tested all the wires in the engine bay to get the tach to work, but it just vibrated above the 0 (almost 50-100 rpms). I hit the throttle and the needle only jumps up to ~ 900 rpms (normally ~4500 rpms).
WHAT IS THE PROBLEM?
I have tried to figure this one out, but can't figure it out. The power is correct, the ground is secured, and the only thing I can guess is the green signal.
For the record, my engine has not been liking the cold and tends to die in the first 10 minutes of operation in 50*F weather (which is one of the reasons I want to monitor my truck, and cause I've been wanting a tach for a while).
I've referenced:
TRS Tech - Tach Install
RPS Tech - Tach Install by Fastmofo
Random TRS Tach Install thread
Quote taken from another 4.0L tach thread:
Reference for people later:
Red wire = power
Black = ground
White = gauge illumination
Green = tachometer/rev signal
HELP!
Thanks for everyone's help in advance,
Pete
I've referenced:
Yo,
Before i read the article here on TRS, the instructions that came with the tach suggested i use the wire that came off the coil pack. (They obiously did not design it for a ranger.) That diddnt work so i found on the site that Ford already wired for a tach, even if your model diddnt come with one. So i found the wire they talked about (The tan one i believe). And it worked just fine.
Red wire = power
Black = ground
HELP!
Pete
