- Sep 21, 2007
- Wa, Bremerton 98310
- State - Country
- N/A
- Total Lift
- Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 32"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
@Nick Ranger - Private Eye ,
Hello,
LIFTER PRELOAD:
Engines that use hydraulic lifters use a "lifter preload" adjustment to keep the valve train working at optimum.
It is not accomplished the same way as the valve lash adjustment, as with solid lifter (which produces a gap); it is an amount of adjustment PAST the push rod contact with the rocker, which forces the push rod into the lifter a specific amount (range, usually somewhere between 0.020" to 0.080", depending on the engine) of the lifter's plunger travel.
Great to hear that you did a good job cleaning up those rocker arms
. It may be worth the small amount of time/effort/expense that it takes to determine what actual length of push rods your specific 4.0l now requires.
Hello,
LIFTER PRELOAD:
