Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
There should be a spec for valve stem installed height.
Did you measure the distance of the gap in your photo?
In case anyone is interested in looking at the other side of the cylinders where the valves function:
I think you may be experiencing seat recession. The seats get pounded out and the valve stem will be a bit higher on that cylinder. Do you have a valve spring compressor to tear it down further?
You're right @avid ... I looked right past the .009
And for the AI... I get it. But by past experience with these sorts of things... it seemed close enough to give you an idea. It was also the first thing on my search.
Typically the exhaust valves and seats take a bigger thrashing then the intakes.
Why are the heads off in the first place?
I would be hard pressed to just reinstall them without freshening them up.
