lilfordrunner
- Nov 12, 2011
Maybe you could swap in a section of pipe from that year with the o2 sensor spot in it, and hook it up.
That's exactly what I was thinking
Crank Postion sensor tells the ECU where the crank is and a cam position sensor tells it where the cam is. The ford 3.0 and 4.0 use a camshaft syncro nizer to ge the cam postion and time the injectors and spark.
not all the 4.0's had cam sensors, not until mid to late 90's. i know my 93 engine did not. not sure how that setup works, i dont have an answer....
Your 93 should have the camshaft syncronizer on it which basically acts as a camshaft sensor and send cam position to the ECU to tell it when to fire injectors and spark.
