4.0 or 5.b
I would rather have a 4.0 because I think it will cost less than a 5.0 conversion. Thanks for your input.
i want to keep the dash if i can. and i guess 4.0 would be better. i will be driving it everyday so its needs to get dome kind of gas mileage.
No need to swap the dash or wiring at all, just the engine control wiring.
Dave
i do have the manual and what would i do just pull the radiator and stuff out too? and exhaust i can do myself i know how to do that.
I am running the rad out of a 4.0 Explorer automatic with A/C. Basically it is the same rad as your rig has now but is twice as thick.
Ok when I have asked about a 5.0 vs a 4.0 into an 88 Ranger 2wd I get two answers, with the 4.0 you will want to swap the dash and the 5.0 is the same amount of work with more benifit.
What I don't get is why is it "best" to swap out the dash for a 4.0 and not a 5.0.
What 4.0? A newer one would really complicate things going into a older truck.
I don't have AC and don't really need it. To me it's just extra drag on the motor and I so could just get a radiator from the same vehicle since ill be there
If you don't check the AC checkbox you will get a single core radiator. I don't have AC either but I need the extra cooling that the radiator for that application supplies for my 302.
If you go with a 4.0 you probably won't need it though, you might double check but I think they use the same single core rad as anything else in a Ranger from the factory. If it is something else it still won't be the 2 core Ex rad though.
Well I could just get the double core radiator and then it will keep the motor cooler right?
Ford thought that the smaller one was good enough for a Ranger...
You are on your own on that one. :icon_thumby:
I take that as a yes.lol my truck already gets warm so o think I'll do that. And with tyranny mounts would I be able to just use the same ones and everything?
