942wdSC
Yep ordered off of rockauto is that why??Get a better sound system. UNLEASH THE WATTS
My money is that you have a walker exhaust. They're eerily quiet.
More than likely. Most walker mufflers are designed to be quiet above all else. If you want to even out the loudness, look into a Flowmaster. They flow a little better as well.Yep ordered off of rockauto is that why??
Keep in mind, dynomax is just a loud (and is made by) walker. I've never had good luck with them on jeeps, and they tend to be restrictive.
Borla is edging on top shelf stuff, up there with thrush IMOI had a Heartthrob dual cat back that was basically just two glass pack tips before the Dynomax. The Dynomax ultraflow is just as loud and seems to flow just fine. It's been on for 4-5 years now and still looks great under there. Unlike the rest of my undercarriage. I had a Borla on my 02 Liberty and that was a nice (expensive) system.
Also I think it's only a 2 inch and it's probably not helping the fact of that matter do you think 2 inch is a little too restrictive or should I be fine?More than likely. Most walker mufflers are designed to be quiet above all else. If you want to even out the loudness, look into a Flowmaster. They flow a little better as well.
Nothing wrong with walker products on a daily. They're a little restrictive, but unless you're building for power, they work fine.
Dangerous question around these parts, and there's a few different answers you'll get:Also I think it's only a 2 inch and it's probably not helping the fact of that matter do you think 2 inch is a little too restrictive or should I be fine?
Ok thanks ?Dangerous question around these parts, and there's a few different answers you'll get:
Some will tell you it's plenty, since Ford designed the engine to run on 2" pipes.
Some will tell you that vehicle manufacturers often cheap out on exhaust systems, and are known to hang restrictive exhaust systems on vehicles to save money on production costs.
I say there's no reason to change out new parts if they work.
So, here's an article that explains some details on exhaust sizing. It's a good place to start, but by no means lists all arguments and theories around exhaust systems:
Performance Exhaust System Design And Theory
Exhaust system design is more complicated than running a few tubes. Look into the fluid dynamics involved in generating scavenging and avoiding restriction.www.enginelabs.com
I'm of the opinion that exhaust systems are one of the more difficult aspects of vehicle tech, and that I absolutely do not know enough to advise someone ??
Electric vehicles are generally much quieter all around.
Who wants damn golf cart? You can keep your ev.
