4.0 duals
ch23119
'04
I am new to the forum and was looking to put dual exhaust on my '04 edge. any pics or advice concerning their adventure with this? I have briefy looked and can already tell i need to a new spot for my tire.. just looking for advice on what people have done before
True duals or just tips? That will be a big question. Legality is an issue with true duals im pretty sure, but everyone will ask that.
well whats everyone advice regarding tips, true duals, or single. i live in ohio as far as legality goes and i'm startin to figure out what i want but want others advice. i want a better sound but also want performance too. i do combination of some city drivin as Im in school, highway and offroading when i got the shot
Dont expect hardly any gains by doing exhaust (except headers). A single exhaust (around 2 1/2" or so) will sound and flow plenty good.
ya, I'll second that, dont expect ANY performince gain from getting dual exaust tossed on. Thanks to high gas prices and emissions standards these days, most new vehicles are pritty effecient when it comes to exausts and what not. Maybe adding headers and getting a well built "tuned" exaust built would help. After a fair bit of research on both gas and diesel applications, dual exausts done realy make a difference on there own.
If you want duals I would just pick whatever muffler with dual outlets or get a y-pipe and take it out however you want. Usually when you go out the back the pipes are outside the frame, so your spare tire should be ok. On a new vehicle it isn't worth loosing the cats just for true duals IMO, especially if it has a V-6.
What about on my 91 v-6 where there is only one oxygen sensor after the y-pipe? I want to run true duals so would it be possible to put he O2 sensor in an H-pipe or would there not be enough exhaust gas in there? I already have headers, no cat, and straight pipe to the back.
I have an 03 FX4 (4.0 stepside) and was wondering if cutting out the length of pipe between the end of the muffler to the exit of the tailpipe would increase the sound.
it will increase in-cab resonance and sound like crap on the highway.
and on top of that, leaving it dumping under the truck will allow the corrosive exhaust gasses to expedite rust of the underside of the truck...not to mention you risk allowing the exhaust to leak into the cab.
I do believe gibson sells a dual exhaust cat back now, I would go with that if I had to do it over.
I have an 06 FX4 and went to LMC Truck and got a dual catback system that did not use a muffler but instead a set of resonators, it was cheap and sounds pretty good. Ive had people ask if I did an engine swap, from idle to about 3,000 rpm it has a nice rumble and above that its not really loud in the cab. I like it but as soon as I can afford it I wouldn't mind getting the Gibson set up
witthout doing a crapload of changes a catback exhaust with a nicer muffler (Flowmaster 40 series , etc ) is probably your best bet.
i have a custom setup on my ranger and i love it. i have the dual cat setup (91) i cut one off and had a chambered box muffler welded to it with a dual outlet with 2-1/2 duals back. muffler is V-force (cheapy) but sounds nice... then i added headers and gave it a nice tone. i would use stainless tips though. its worth the money they last a lot longer. i bought magnaflow stainless rolled edge 12 inch tips... just remember the longer the tip the heavier they are which can mean breaking hangers.
here's a video of my truck you can get some sound out of it to hear...
4.0 duals
picture of my setup. receiver is gone now and the pipes are evened out lol
4.0 duals
