36lb Injectors MAF question
thefourohrangerkid
I couldn't manage to get the search engine to work so I don't know if this has been made before
but I'm getting ready to put 36lb injectors into my 4.0, stock everything..
Where can I find an already calibrated MAF for these?
Where are you going to get the extra air to go along with all the gas?
All the MAF sensor does is tell the PCM how much air is entering the intake.
I'm going to be putting the bbk 66mm throttlebodies and a high dollar cold air intake. I was told that for the injectors though that I'd need the MAF recalibrated.
yes and where in the heck are you going to find a cold air intake. I've looked. NOBODY MAKES ONE. you would have to make it yourself, and it would still look horrible.I also have a 94 4.0 ranger XLT. besides with bigger injectors you run the risk of blowing fuel past your rings my buddies 00 Implala has 36 lb injectors and thats what has happened to him. I gained alot of power just by removing my stock exhaust and replacing it with a super 40 flowmaster. DONT run this motor as a straight pipe, Theres no back pressure to keep it running right...
The OEM intake is a COLD AIR INTAKE! And since it flows way more air than the engine will pull, you won't get any more air with a K&N type of intake. All it will do is reduce the velocity of the air flow, and it will pull hot air in.
