- Aug 6, 2007
- Manual
Wrong, the blocks are not the same. Totally different design and casting.
Not as streetable ? BS. And you won't need to add 4 bolt mains. If you're looking for a std bore core, I've got one for sale. $300 for the whole thing. std bore, std crank, just as Ford built it in 1972. Jumped time, timing chain stretched. Top it with 2 bbl Aussie heads or quench 4 bbl heads plus intake/cam/carb and you've got 400 horses without trying.There's a 351 Cleveland truck on Youtube. Anyone here belong to it?
http://www.youtube.com/watch?v=I0wW7fQiAts
I've been drooling over 351C's for a while now and seeing vids like that make me really want to build one. It would likely go into a late 60's Mustang or Cougar instead of a Ranger. I consider myself to be a bit old skool and find buying and assembling new performance aftermarket cores to be too easy (and waaay too expensive for me). That's why I've gradually fallen in love with the 351C. An OEM fire-breathing dragon that would just need a cleaning up of the stock block and heads, a DIY rebuild with hopefully non-overbore pistons, perhaps drilling for 4-bolt mains if not already equipped, then cam, carb, and exhaust to match. Perhaps a new intake, especially if you've got a 2bbl and want 4.
Not as streetable as a Windsor, but will still kick ass with factory heads for those on a tight budget.
I guess by streetable I really meant power band. The 4bbls only really woke up in high rpm's. A guy I know has a cleveland in a '67 fairlane and a C6 behind it and even with a hi-stall t.c. he still wants to convert to a 5spd to get more power down from standing starts.
What intake and carb is he running ?
