31" fit
the ranger should have one more spring than ur b2. i used to have a b2 and my friend had a ranger. his had one more spring. if u put those springs on ur b2, the 31s should fit on the rear, as for the front... its gonna need some fabricating.
thanks for the deets.:headbang:
on a second gen ranger, 31's will fit without lift using stock wheels without any serious rubbing (only on radius arms and sway bar), on a first gen you're limited to 235's pretty much, even on a second gen BII it's limited because of the rear inner fender generally.
I've been running 31's on my '90 ranger ever since I converted to 4x4, most of the rubbing went away once the tires wore a bit and when I removed the sway bar...
My 88 has 31" tires on stock wheels with very little rub when offroad.
This is a pic i took a few days ago. The tires dont touch the fenders at all, but rub the wells in the rear.
have had no problems my 31's yet. but i do just lite offroading, getting to fishinh holes.
yeah these are 10" wide i believe. and i VERY rarely wheel. maybe once every two months and even then. im on the sand, or on a well traveled trail. i got my front end torn off and getting swapped f rom gen 1 to gen 2. would i have any issues with street driving?
No, mine only rub the sway bar when maxed out turning. 31x10.50 15
Back have no issue what so ever on road, and are ok off. As long as your springs are in good shape.
Not to be a party pooper, but it looks like th parts truck has fender flares. I mean first/second gen beds are the same and my fender is way smaller then the ones on that one. I think that may be where the room is coming from.
