Hey all! My 99 has me scratching my head. I replaced both head gaskets less than 200 miles ago and now my cooling system seems to be building pressure. I can’t trace it down. I have:
-replaced t-stat
-replaced radiator cap
-ran til hot w/cap off to bleed air (don’t have a vacuum filler)
-confirmed that coolant is making its way to reservoir upon reaching OT & pressure (level stabilizes after expansion)
-confirmed that the reservoir does not bubble with engine running or after turning off.
the catch here is that the upper radiator hose starts leaking coolant out of where it slides onto the radiator and the hose does feel quite stiff until bleeding all the pressure to the reservoir. I haven’t replaced the hose to confirm the hose is fine but I just feel like it’s building too much pressure. I don’t know how unless my new head gaskets are toast. It appears to be intermittent too. I bled the system Saturday, took it for a 10-15 minute drive afterwards and nothing leaked. Got in it to drive to work this morning and was leaking coolant out of the hose again about 7 minutes down the road. The heat is also hot (not great but definitely enough to keep cab warm). I’m getting frustrated with it! Anybody have any ideas? Maybe I’m overlooking something? Hoping to feel pretty stupid once I find it. Thanks in advance.
-replaced t-stat
