The truck I am converting is 1990 the drivetrain comes from a 1988 both have same body style (xlt ext. cab 2.9L-5 speed). I switched speedo cables (2wd cable was way shorter) and I am trying to figure out how to wire in the manual transfer case and tranny so when I shift into 4wd the light behind the dash works (I noticed the bulbs and wiring is all there when I removed the instrument cluster to switch speedo's) and the other sensors on the mits fm146 trans. I carefully combed the Haynes electrical diagram with no help on the 4wd lighting circuit!! So there is some confusion on my part about how to trace the wiring
. . . I already have the engine crossmembers switched and bolted/welded into place and mounted the front axle . . . just some last minute electrical buttoning up before I throw in the engine and tranny/t-case and mount the drivelines and fire it up.
