kimcrwbr1
Yea the choke thermostat will hold the choke all the way closed when you push on the throttle half way down. When you start it the pull off will open the choke around 5/16 to a 1/4 of an inch giving it a rich condition. Adjust the high idle speed and the more spring tension the longer the choke stays closed and the idle stays high on mine I have the choke set to be fully open after about 10 minutes. If you have it right you should be able to start it and go with little or no hesitation I press the throttle about half way down and it starts right up after sitting for a couple weeks.
