2011 Ford Ranger Sport - Fog Lights staying on
Featured Build Threads
Gunner862
ASE Certified Tech
Ottawa
ON - CAN
Vehicle
Drive
4.0L
Torsion bar level front
255/70R16
Hey all,
I was at my Bother's place tonight and noticed my fog lights were on despite everything else being turned off. I could not get them to turn off without removing my 15A fuse. I swapped relays but no change. The control side of the relay seems to be shorting to Battery (+) (I think). Normally the fog lights only work when the key is turned on and the headlight switch is pulled out. Switching to high beam turns them off which is normal. I played around with the fog light switch, ignition switch and multi-function switch in different combinations, sometimes the fog lights momentarily turn off (with all other switches off) but then come on again shortly after.
I'm wondering if anybody has come across a similar problem, and if so, what was the solution. I have yet to check anything and just have the fog light fuse removed for now so the battery doesn't drain.
Your foglamp relay is controlled by grounding the brown wire between the underhood fuse box and the underdash fuse box. These are "smart junction boxes". They are fuse boxes with electronic circuit boards underneath.
If you pull the relay under the hood, the foglights go out?
Yes, removing the underhood relay also will make the fog lights go out. I can hear the relay click on as soon as it is plugged in (with the 15A fuse also in).
No more simple wiring. It's all computer driven by 2011. If you wanted to dive deeper you could possibly download Forscan and buy a cable for your laptop. Then you might be able to see if you can control it, or there is something wrong with the transistor in the smart junction box.
For sure. My smart junction box is behind the passenger side kick panel. I have a suspicion it might have gotten wet. Thanks for that wiring diagram by the way!
I am thinking but not sure, you might be able to get another from the wrecking yard, but it needs to be programmed into the system for the truck to recognize it. I do not know if Forscan can do this. Or there are some places on the internet that will repair boards and keep your VIN programming in it.
While browsing online for a replacement sjb by p/n I saw a seller or two that I think program them for your particular vin, likely for a fee.
Event Coverage
Featured Ranger Based Vehicle
