Took a look at a friends 2011 Ranger because the 4WD wasn't working. The 4WD light was on, but only the rear tires had power. Turned the switch to 2WD and 4Lo but nothing happened. Checked the switch with my meter and it looked like it was working (different resistances on pins 2 &3 at the different positions). Took the transfer case motor off and tried the switch again but the motor never moved. I turned the transfer case shaft and it appeared to go into the different gears but the light on the dash never changed from 4HI. So right now I'm thinking the transfer case motor is bad with other possible problems too. Is there any way to test the computer module to see if it's bad too? Any other items I should check?
