- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- 5.0L
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
2010 Forte Koup. 170k+ miles, all driven by me. No major mechanical or electrical issues since purchase. Well outside warranty, this wouldn't be covered anyway, and I am NOT going back to the dealer for anything more than 60k mile transmission services. That mostly because I don't want to do it myself and they'll use the OEM filters.
This isn't a new issue, started some time before the end of last year, so between 6 and 9 months ago. I never worried much about it, until the issue bit me in the a$$ this morning.
Back to the beginning, I have got remote start in my car, it's the dealer add on unit. I installed it myself and know its installed correctly. It's worked great from the time I installed it until this started. This first appeared when I went to remote start it one morning last year and it wouldn't respond. Didn't think much of it because occasionally over the years one of the door sensors or a trunk/hood switch would hang and stop it from working. Open and shut the door, or trunk/hood and it would go back to working. Didn't think about it right then because I hopped in the cae, it fired right up, and off to work I went. Haven't used the remote start much in the time since because it isn't needed all that often, I tend to use it more for cooling off the car in the summer than warming it up during the winter.
Since then I've noticed that in the mornings it sometimes (oftentimes?) won't respond to the key fob at all. I've replaced batteries in both key fobs and both get the same reaction. They work, but first thing in the morning its intermitten. After I fire the car up and drive into work it works fine for the rest of the day, next morning the same thing. Where I live the car doors normally stay unlocked anyway and every time I can hop right in, fire it up, and take off.
This morning, in the mid 40s, I decided I'd try to remote start the car and let it warm up while I rolled the trash can down to the road. Threw my lunch in the car, hit the keyfob. Lock button twice, start button once. Doors locked, but no start. Tried again, no start. Ok, there's also the option to start the car manually, press the remote start bvutton and remove the key. Press the unlock button, no response.
At this point everything is fine. Drivers door still has a key hole right?! Stick key in, turn key, lights flash, door doesn't unlock. Turn key other way, door doesn't unlock. Keep trying. DOOR DOESN'T UNLOCK! So no physical connection betweendoor lock cylinder and kocking mechanism, F%#&!!!!
No choice, I've got to call in today. I've got other vehicles, I can buy another lunch, but I can't go to work without getting my ID badge out of the car. I'm not breaking the window and no other way into the car.
Since then it's decided to respond to the key again and I got the door unlocked, but I'm not trusting it. I've already called in and informed my boss that the car was possessed and I would be late at best. Since I've already taken the time off I want to try to get to the bottom of this.
I think I'm going to pull the battery and have it tested, but I don;t think thats the issue since every time it has enough juice to start the car. I just don't know anything else to try/check. Have y'all got any ideas?
