2008 Ranger manual RPM's don't come down smoothly
LiamMacDonald
Windermere
BC - CAN
Vehicle
Drive
Hey guys, I’m having a bit of an issue with my Ranger. When I let off the throttle, the RPMs don’t drop smooth they kind of hang and fall weird. I've cleaned the IAC, MAF, throttle body and lubed the throttle cable all resulting in the same choppy deceleration. Could this be injector related or what would you guys recommend I try next?
Sticky PCV valve? Vacuum leak? Not much to go om there.
Doubtful it's injectors.
Once the idle drops... does it ever jump back up or hunt for a stable place to be?
If so... vacuum leak
No, once the idle drops it maintains a steady 650-750rpm when warm. I've looked pretty hard for a vacuum leak and have been unable to find anything.
I've heard of earlier (Like 90) trucks doing that with an automatic PCM and a manual transmission or if the speed sensor wasn't working on the manual trucks.
Could it be some kind of feature by 08 to hold RPMS up for a second to match gear speed for easier shifting?
