2007 Fog Light Mod Instructions?
THE H.P FREAK
WINDSOR, ONTARIO, CANADA
HI!... O.k I want to do this mod but with everything else electrical I've tried to do to this truck, nothing works out due to FORD redesigned the electrical system of this year. I need to know which two colour coded wires to modify to do this mod? In the link below I have neither of the two colour coded wires in my 22/29 harness. Any help on this would be greatly appreciated.
http://www.generation-edge.info/topic.asp?TOPIC_ID=5033
HI!... Well apparently I've been told that this mod can't be don't on the newer 2007 to current Rangers. So, I'll probably just do what the F-150 guys do. Install a switch in the dash and wire the fog lights only to this switch via a 30 amp relay. This way I can run the foglights without the headlights on or with them on including the high beams. I'm going to work on this, this weekend.
HI!... Well I have a buddy that's good with electronics. He got the wiring diagrams for my truck. Doing the foglight mod on my 2007 is almost identical to the current instructions, for the exception that I have to run a single relay. The two wires are still in the SJB. So everything will be nicely tucked out of the way under the P/S kickpanel. Shouldn't take us more than 30 minutes to do it. Were doing it this weekend, so I'll post up picks and a how to if everything goes well.
Do you want to do this because someone else did it?
Foglights serve a different purpose.
If you want auxilary lights that go on with your high beams
get a set of driving lights.
AD
