- Feb 21, 2021
- Age
- 38
- Mitchell , IN
- 2.3 (4 Cylinder)
- Manual
- Tire Size
- 235/75 R15
Need to know what the volts should be for the Red/light blue Wire leaving the ignition switch?
battery is good and not every wire on the ignition switch has 12v or higher but im not really sure if i have the Wire that controls the starter but if the red wire with the light blue stripe Is supposed to have +12v then its extremely lowNeed to know what the volts should be for the Red/light blue Wire leaving the ignition switch?
Straight from the ignition switch if I do voltage on the blue and red wire it is very low and sometimes even in the negative so is it something with the ignition switch? Cuz I just replaced it not knowing if it needed replaced but it was when I was having the initial problem with the PCM not powering upAnd you tested both slot of fuse 21, only 1 should have 12v with fuse out
If so then the wire from ignition switch to fuse 21 is bad, or connector in SJB is bad
SJB Connector numbering seen here: https://www.therangerstation.com/fo...er-fuse-diagram-smart-junction-box-jpg.30179/
C2280A on the left then counter clockwise to C2280D at top right
In the diagram above you will see C2280B wire 27 should be the red/blue wire from ignition switch, it should have 12v with key turned to start
That goes to fuse 21 via connector then out of fuse 21 to C2280A wire 31 and out to clutch switch
Okay I checked fuse 21 It didn't have 12 volts with the key turn to start it got 0.40 volts at the highest. So I'm a little lost at this point on what my next step would be
This 2004 horse would easily put your 1990 to shame and would end up shooting itself due to the embarrassment should probably consider thatWell, when your horse is suffering you shoot it, so that might be a step you would want to consider.
Sure, could be ignition switch, new doesn't mean "it works" anymore, new means NEVER TESTED now-a-days
Unhook either battery cable and pull out ignition switch
When you have ignition switch out hook battery back up and test the Yellow wire(s) yellow wire has 4 connections in the ignition switch, only 1 is used to power red/blue wire in START
Its the B4 wire/connection
red/blue is on the STA connection
Ok ill throw the old one back in and test again thank you, ill post update after i switch it back.
