2004 Ford Ranger 4x4 XLT - speedometer problems (that are more than just it bouncing)
Griffith
IN - USA
Vehicle
Drive
Question: I've replaced the wheel sensors, the hubs, the ABS wires, and everything I can think of (that I can do) to fix this. Still a problem. The speedometer is fine for about twenty minutes, then it'll start jumping all over and feels like the truck is losing speed when it does that.
What could it be?
Just to be sure, you checked the ABS/Speed sensor and it's wiring in the rear differential, correct?
I had a mechanic shop check it out three weeks ago (and I fixed everything on the diagnostic) because of this problem. They didn't say anything about any electrical (outside the wheel hub ABS sensor). Do you mean the sensor on top of the rear differential? I replaced that and the one on the transmission in front a few days ago.
Still have the issue.
Would the tone ring be the problem? Or the differential itself? Not a pro mechanic or anything (me and my neighbor fix up what we can on our vehicles) but I am starting to think in that direction (tone ring, differential). And when I took the back sensor off, it dripped a couple drops of what look like water.
But I could live without the speedometer if need be (phones have MPH now on them) but the loss of speed (it seems) when it does that is more my concern.
Yes, the sensor on the top of the differential. From what I understand, from 1998 until 2009, speed was picked up from that sensor as well as performing an ABS sensor. At least that is how my 1998 Ranger was setup.
An issue with the tone ring in the differential would not be a common problem, but not impossible either. I can't think of a reason something would happen with the tone ring unless something in the differential failed and flung chunks around, like ring or pinion teeth or spider gears breaking.
From what you are describing, if it was a problem with the tone ring, it would be all the time and not after a few minutes of driving.
If the shop did their due diligence, and nothing is wrong electrically, unless there is something in the PCM or one of the other modules, it leads me to there being an issue with the instrument cluster. Cracked solder, broken wires, a defect in the circuit board, or the speedometer itself is failing after it has some time to warm up. Heat expansion could be causing something to open up. With fine electronics, it doesn't take much. I don't know if the speed signal is a direct feed to the instrument cluster or not. A wiring diagram would provide that answer. Unfortunately, the book for my 2011 would not being any help since the system is different in it.
To add: tonight as I drove home from work, the speedometer started going crazy, my O/D light came on for a few minutes, heard a thump underneath and it went off but the speedometer kept bouncing the whole way home. And while in my garage, I had it in park - the speedometer was still jumping around, especially when I hit the gas.
That is starting to sound like a wire issue. Like something in the steering column or under the dash.
I know the O/D like can be a worn wire in the column coming from the O/D button on the stalk, shorting out on the support structure or the shaft. It's been posted about before.
In your opinion, I drive about seventy miles a night to work and back - do you think it'll be okay till Monday (my next day off)? Plan to take it another mechanic shop on Monday to have this figured out but I don't want to make anything worse. I work in Chicago but live in Indiana and do not want to get stranded on the south side of Chicago at night.
Understandable on the south side of Chicago thing. It sounds like the truck can drive just fine, you just don't have all the instrumentation. Not being there, I can't make a call on whether you should drive it or not. One of the big downsides to conversations and troubleshooting over the internet is that we aren't there to see everything. So, something important might be getting missed.
It got worse last night. Speedometer started bouncing. O/D light was blinking for about a minute and it went into limp mode when it did that (didn't do that before), then a thump underneath and the light went off (but the speedometer kept bouncing the whole rest of the way). While parked in my driveway, the speedometer kept bouncing and especially so when I gave it gas in park - and each time I gave it gas, there was thump underneath. Recorded it but this site doesn't allow me to upload vids.
Talking to my neighbor today: showed him the vids, he said not to drive it anywhere but the mechanic Monday if it's the torque converter as that'll ruin the trans.
