2003 Edge PO352,PO300, PO303, PO304, PO316
teched
Hi guys, I just got done putting a new clutch, slave and master in my Ranger. I drove it to work today and it ram fine for about 10 miles. I stoped and grabbed a cup of coffee and when I started the truck to leave in started to run rough. Low idle, no power. I think some of the codes above a specific cylinder misfires, and the 352 looks like a coilpack??? Having a hard time decoding. Any help appreciated.
p0300 random misfire
p0303 and p0304 are misfire detections
p0316 missfire in first 1000 revs
p0352 ignition coil b primary/secondary circuit malfunction
all seem to point to a coil problem or a short in the wiring
I'm thinking coil also. Thanks
changed the coil pack with a junk yard one and it seams to run OK. I did have an initial rough idle, but I did drive it 25miles with misfires, so the plugs where probably soaked. I will reset my codes and give it run. Thanks for the info.
