Uncle Gump
Boomers gotta Boom
TRS Event Staff
⭐Supporting Member
TRS 25th Anniversary
GMRS Radio License
- Sep 17, 2018
- Ottawa IL
- State - Country
- IL - USA
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 2.9 V6
- My credo
- Lead follow or get out of my way
@Mr.Wizard
Did you get your truck back together?
Good points made with tire clearance and gear ratios mentioned above. With the lift you have as @DRanger024 mentioned... 33X12.50's will fit most likely with zero issue. I chose 32's with my 4.10 gear... to put 33's back in the sweet spot would require a gear change to 4.56. But lots of folks run 33's with a 4.10 gear.
As for your fender flares.... those look like factory stuff to me.
