- Mar 10, 2008
- Age
- 38
- Aurora, Colorado
1984
196
- Automatic
Hey, I have a 2001 with the SOHC. When ever the thing is under a slight load, especially when the throttle is as far down as possible before a down shift, it pings like hell. It has 130k on it and has been doing it since 109k, that is when I purchased it. I cannot pull codes, however I used a cheap scanner. I tried better gas, I also ran small amounts of water through the intake to clean out carbon. I have done that at least five times until it starts to misfire. The engine does not smoke or leak, all the miles where highway and it runs like a champ otherwise.
Is this typical? I build engines all the time, but this is the first fuel injection I have ever owned. The O2 sensors where changed at 80 or 90k like they should, the plugs are new as of 10k ago. I installed Autolite double platnum, and the wires are new as of 2003 at about 50k, as far as I know.
If I shove my foot to the floor, there is no pinging at all, just under a load without a down shift. Thanks!
