DaimonCarpenter
So if there is not a wire for number 19 what do I doThank u I will have to get back with u on it
The OBD2 reader seem to read the correct speed from 50 all the way to 80You will need to add a wire to pin 19 or get the SGI-5E interface
But I am still puzzled about you getting a speed signal on the OBD2 reader????
Where is that coming from?
Is it correct, or close enough
GEM module or 4WABS module are the only 2 sources
Adding the wire to pin 19 where do I wire it intoThe OBD2 reader seem to read the correct speed from 50 all the way to 80
I guess I'll have to use the 58 pin on the PCM wiring instead of pin 19 on the 4wABS cuz there's no pin or wire in 19. Other than wiring into the cluster where else do I need to wire intoThen you have a speed signal at the PCM, just not sure from where, my guess would be from 4WABS?
But transmission shifting should be OK if so
On the PCM pin 58 should be a grey/black wire, on a 2000 Explorer PCM, thats "speed signal in" from 4WABS
So lets assume thats the case
PCM connector numbering here: https://www.ranger-forums.com/attac...ve-97-4-0l-ohv-pcm-pinout-97-explorer-pcm.png
Check that pin 58 is the grey/black wire
You will need to splice into this wire, and run wire into cab and splice it to instrument clusters, grey/black wire, don't cut the grey/black wire, splice into it at both locations, as that should get Cruise working as well
There will be a grey/black wire at pin 19 on 4WABS so you can splice in there instead of PCM, up to you
There's no wire at Ben 19 on the ABS so I will have to use the 58 on the PCM and wired into the cluster and what other location just to be clear.Then you have a speed signal at the PCM, just not sure from where, my guess would be from 4WABS?
Hi, New to the forum, I have followed this thread and have tried to get my speedometer working, (2001 3.0 ranger with 2000 mountaineer V8 swap) I connected a pin to my 4x2 ABS pin 19 , also connected a wire to pin 58 on the ecu, connected them both to pin 1 on the black cluster plug, (grey/black).
I still have no speedometer working, do I need the mountaineer ABS unit swapping in?
Thanks.
