2001 Ranger ExtendedCab + FlareSideBed + V6~4.0L~SOHC Engin + 5r55e Trans + 1354 TCase;
same Frame+WheelBase+DriveTrain as 2001 SportTracJob2:
* Would not trust OdoMeter@40kMile=1700Mile/Yr on a 24yo Vehicle; 150kMiles+ is typical;
InstrumentClusters thru 2003 Models are easily swapped out to a LowerMileage unit?
* Would be concerned about Engin Timing component damage;
have TimingTensioners been renewed; have routine 4kMile\6mth Oil+Filter changes been done?
* Would be concerned about Trans; commonly wear out (Slipping, loss of OverDrive\Reverse,...)
at >100kMiles if not serviced; have routine 33kMile\4yr ATF+Filter changes been done?
* Would be concerned about 1354 TCase; have routine 33kMile\4yrs fluid changes been done?
Does 4x4 system shift proper thru 2WHi~4WHi~4WLo; ShiftMotor+ControlModule failures are common?
* JunkPlastic ThermoStatHousing or HeaterControlValve or Radiator, cracked\leaking?
