2001 4.0 won't start
Skunk423
Law Enforcement
EMT / Paramedic
Firefighter
Ham Radio Operator
Nampa
ID - USA
Other
2019 F-350
Vehicle
Drive
Bought a 2001 Ranger XLT 4X4 with the 4.0 so I wouldn't have to commute in my F-350. It didn't run, and the guy I bought it from said he had changed the coil, which didn't help. He had also changed out the cam and crank position sensors. I found no pressure in the fuel rail, so I thought fuel pump, so I changed that out. It cranks, but it acts like the injectors aren't opening like they're supposed to. There's power to them, but I'm not sure the ground is working. My understanding is that the power is normally on to them, and the PCM grounds them out to open them.
I changed the computer because it was about the same cost as getting a couple of new keys, but it didn't help. I don't see any loose or broken wires under the hood.
I don't get any errors in KOEO, and I'm getting good spark.
I got a really good price on it, so I'm OK putting a little into it.
Any ideas?
Typo is my bad. It's a 2001, not a 2021.
To have spark the PCM is on. You have power to the injectors. So the only thing left is bad grounds from the injectors to PCM. Or timing...
Fuel - Air - Spark - Timing. I'd add compression but that rarely just goes away especially on all cylinders of a V engine.
I thought the same thing. Each injector has its own ground, controlled by the PCM, so there has to be a common thread to make them all go out at once. Do you know of any connectors that would involve all of the wires?
Or is there a good diagram of the pinouts for the PCM?
Thanks, SenorNoob, that's a great site!
I think I found the issue. Pulled the left valve cover off and it looks like one side of the chain tensioner is broken, so the chain has a lot of slop. I would expect that to throw the cam timing off enough for the computer to shut off the injectors.
