- Dec 27, 2007
- Age
- 40
- Manual
i have a lifted 90 ranger 2wd with a 2.3 and manual trans. i stumbled across a 89 in the junkyard that was 2.3 4x4 manual trans. picked up the trans for 80 bux. i just did a brand new clutch in my truck a few 100 miles ago and was wondering if the clutch is the same for 2wd and 4x4 trans. is there anything ill need to do im forgetting? just swap it in with the 4x4 rear drive shaft and should be good to go? also wondering if i run the 1350 manual tcase can i run it with out a front driveshaft in place for a while, or with it being a slip yolk will all my fluid be flying out. i planned on getting the trans and tcase in and still be driveable before i get around to doin the solid front axle.
please help
thank you
please help
thank you
