2.9l vs 2.9l cosworth 24v engine swap
ref cosworth conversion
im putting one in my 88 supercab at the moment,engine mounts the same box the same,bit tight around bulk head left hand side,l/h side exhaust mamifold bit close to steering but real easy swap,a lot of engine parts same as 12v got no problems over here in getting parts but u may have to get stuff shipped to you if u need it,plenty around over here and most peaple will ship to states
good luck steve
I love just about anything Cosworth has ever done with Ford. Seeing as the regular 2.9 shares alot of similarity to the Cosworth 2.9, I don;t see many problems in the actual swapping of the engine.
You'd be doing an injustice by NOT swappin in the Cossie.
good luck steve
Keep us updated on your swap, I am planning on doing this aswell, as a complete car goes for around 1500$ in Norway (they all have broken A4LD's, and who wants that tranny anyway`???
Tommy
if it's a cosworth, its not a north american spec car. from what i hear the cosworth 2.9 is a dohc that makes somewhere in the 190hp range. definitely worth the time if not for the 'cool factor' alone. i cannot say how easy/difficulty the swap would be though. if it will accept stock motor mounts and a stock clutch and trans (or 4.0 trans) i say go for it!
hi
yes the cosworth its the same block with the 24 valve on it my question is could i use a 2.9 ecu with that cosworth engine i dont have a ecu thank
