Josh51
- Feb 22, 2023
- Santa Ana, CA
- 2.9 V6
- Manual
Mod Edit:
See post 6 before trying this.
Getting my 86 Ranger ready for my daughter to start driving and one of the things that was a problem is the sloppy shifter. I was about to buy the Core Shifters aftermarket but I decided to pull the shifter off first to take a look at it hoping to save myself $400. I had a bit of up down play but the biggest problem was that I could almost rotate the shifter all the way around. It made it really had to get into reverse. The green ball at the bottom of the shifter that sits in the cup on the tranny was perfectly fine, it fit snug. My problem was the white cam/bushing that sits inside the shifter...it has two wings/nubs on it that fit inside the grooves on the black housing, those nubs have worn themselves out over the years and allowed way to much travel. Unfortunately I couldn't find a replacement cam/bushing. So I decided to attempt to make new nubs. This is first how to write up so bare with me. These first set of picture are the condition of the cam, worn nubs, grooves in the housing and the amount of up and down play of my shifter. Ill make a second post for the how too
