2.9 Transmission Swap
ty.forestcom
USA
So I got my doner truck…
I own a 1998 2.9L 2wd automatic. I am in the process of standard swapping. I picked up a 94 4x4 3.0 with my trans and everything back from the engine. New clutch but need a flywheel. I’m having trouble finding what will work online. Any help is much appreciated.
Thank you.
The 3.0 transmission will not bolt up to your 2.9 engine.
Also the 4x4 transmission will not work in a 2wd truck
I was hoping to use the transfer case and just not have the front axle. From what I read on here before purchasing the 3.0 and 2.9 were interchangeable. Is there any way around this?
Sorry, no way around it. And I find it very unlikely you found that info on this site. Its a fairly common question and it comes up a lot.
I am feeling dumb now but the can get what I paid for it. Thank you for the help. I confused the 4.0 with the 3.0. I was under the impression the 3.0 was compatible and not the 4.0.
I bought the doner truck knowing I’d need a lot more parts than just the trans, would I still be able to use the clutch, slave, pedal assembly etc.? And just look for a 4.0 alone? I need a flywheel anyway. I paid so little for the truck I could get more from a scrap, but would like to pull what I can off of it.
I'm not sure if the 98 and 94 share the same clutch pedal mounting. Sure wouldnt hurt to take a close look. And scavenge whatever parts you can. Sell what you can and put the money towards the proper trans. A 4.0 swap really wakes up the truck too.
Can we get the information straight first? because op says he has a 98 with a 2.9
Yeah, I’d look for a 90-92 4.0 for a donor and use everything.
For that matter, knowing what I do now, I wouldn’t hesitate to run a 4.0 automatic as long as I put a little money and effort into making the transition happy. My 92 was the eye opener… when I had to replace the engine, I decided to try and make the transmission happier in hopes it would last. I had a suspicion the torque converter wasn’t doing what it was supposed to, and I’m not sure now if it actually needed replacing, but I did it because the motor was out anyway. Then I figured that I might as well throw everything at the valve body that I could (shift kit plus recommend mods from over on the Explorer forums), plus adjust the bands, new reverse servo O-rings and gasket (the Aamco Transmission shop guy was really confused when I asked for those but that’s usually where the transmission starts acting up on these), new filter, a second auxiliary trans cooler, new fluid, adjusted the bands, and a new pan with a drain plug.
Took awhile to work all the air out of the system and then she would have spanked my green 00 in a drag race. 3.73 gears with a limited slip rear and 30” tires. Green 00 had 4.10 open and 31” tires then with a 4.0. Probably would give my current green Ranger configuration a run for its money. That 92 would smoke the back tires, both of them, if you nailed the gas too hard from a stop. No joke, if I was running empty and really railed on it, it would sometimes bark second. I’ve become a huge advocate of at least a shift kit, extra trans cooler, adjust the bands and freshen the reverse servo since. I’m currently throwing a stage 2 shift kit at my green Ranger. I’m hoping that it might bark second…
