2.9 to 4.0 swap
Fuel Line Swap
My Doner 92 Explorer 4 door 4.0. I swaped the complete fuel system. First I removed the bed
2.9 to 4.0 swap
I removed the fuel filter and installed the fuel line section from the ex.and swaped it. this bolted in the existing holes on the frame
2.9 to 4.0 swap
I took out the old fuel pump and put a couple slots in the bkt. to hold fuel filter. I think I could have used the ex filter bkt. but I lost it and found it after the mod.
2.9 to 4.0 swap
I removed the fuel lines from the ex and the fuel pump and fuel level assy. I installed the assy into the tank. I had to bend over one of the orientation tangs.
2.9 to 4.0 swap
I started to lay ouy the fuel lines. You can see the direction I chose. My idea was to rout the lines back thru the frame for protection.
2.9 to 4.0 swap
Once the lines were bent I tucked them in and lightly tweaked the lines to fit nice. I used the tubing brackets to help and as rub protection
2.9 to 4.0 swap
Once I got that done I crawled under the truck to do a check fit. The solid fuel lines magicaly fit into the old brackets and the fuel lines ended exactly where they needed to be.
2.9 to 4.0 swap
Here are more pics. I had no real idea this would work out but I had nothing to loose by trying it and it came out nice. I feel comfortable with the setup and I am sure I aint going to have to spend any time fooling around worrying about leaks. I spliced nothing.
2.9 to 4.0 swap
2.9 to 4.0 swap
2.9 to 4.0 swap
2.9 to 4.0 swap
