2.8L Keeps leaking oil at front of oil pan
Update:
The repair was ok till I put the radiator hose on and the pressure from doing that opened the crack back up again. May try to seal it with something else just to get through the rest of this week till sunday when I can tear it all apart and take my time.
Just an update, on closer inspection due to having a cracked radiator I decided I may as well do a little bit more digging into this oil leak. Looks as though my crank seal is bad for sure, so I'm gonna tackle that while I have the radiator out.
Also, my idea of using JB weld didn't work at all, or the JB weld I have isn't any good anymore, it slowed the leak down so if I keep up with daily fluid checks I'll be ok through the weekend till Sunday when I have the time to replace the radiator.
