2.8 with 3.8 FI
Crashtest84
Tulsa, Ok
I read the not so informative post on the 3.8 FI for the 2.8 how is this done and where do you put the injectors aren't the 3.8s a multi port with 6 injectors? if not what yr should you look for if you were looking for a doner ?
This isnt the right forum but ill give you an answer anyway. Early fuel injected 3.8s were throttle body injected, the throttle body will bolt right on. So you don't need ports for injectors.
