- Dec 6, 2009
- maplevalley WA
- Automatic
Have you adjusted them to spec yet, your putting the cart before the horse I doubt any of them are bent. It is a pain adjusting them correct but get two cover gaskets and take the time doing it right, If your oil pressure is good with the 10w30 you dont need to fix it just adjust the valve lash on all of the cylinders to balance the air flow thru it.How do you tell the difference between a valve tap and a bent push rod(s) when it comes to noise..
