redgooch
I run a 200 amp alt. and a duel battery setup. The electric fan i run only uses 18 amps and moves 2100 cfm. So the fan is just a fart in the wind (no pun intended) which has no effect on the electric system. In my case the electric fan is much better than the stock fan. The electric water pump makes a difference too. I have said it before and I'll say it again, reduce parasitic drag and rotational mass it frees up power to go where it is needed, the tires.
