2.5L ('98-'01) 2.5L p0445 code
Greenville
SC - USA
Vehicle
Drive
2WD
2.5 (4 Cylinder)
1998 2.5 5 speed. Truck starts fine, drives fine. It ran really rich for a couple years with O2 heater circuit codes active along with p0172 (rich condition). I replaced both O2's, the codes always came back. Changed pcm to a junkyard one and the O2 codes have not returned. The pcm switch was 3 days ago.
Now I don't smell fuel anymore, but I have the p0172 and a new one, p0445 (evap purge valve circuit shorted). I changed the purge valve, code returned. How should I go about testing the circuit to figure out the short?
Can a shorted purge valve circuit cause the rich condition?
Thanks!
P.S. I'm getting about 17.5 mpg city and 22 highway..I think those numbers should be higher.....
Evap purge could cause rich. IF it's stuck open and pulling fuel straight outta the tank. I'd find the vacuum line going to it and and plug it as a test.
Fantastic. I'll try that. I confirmed last night that the connector for it does have battery voltage. The short would have to be on the switched ground wire to/from the pcm. After I test the purge valve, I may run a new ground wire to the pcm connector and see if that fixes it.
