1999 Mazda B2500, ~145,000 miles.
Here's what happened:
I accelerated up an on ramp and when I shifted from third to fourth, not much happened and I started to slow down, like I would give it all the gas and the engine did not respond. I don't have a tach, but I think the revs were falling. I pumped the gas furiously and was able to kind of sputter off the exit to the side of the road and then into a parking lot. It was making some knocking sounds and nothing would happen when I hit the gas unless I floored it, then the back tires would chirp and lunge and it would move a little. It was idling terribly (and smelled pretty bad too, no smoke or anything like that though) when I parked and then it died. I poked around and jiggled some wires and hoses for about ten minutes. I looked under to see if anything was leaking and didn't see anything. I started it back up and it seemed to be running...fine? I made it through the city without incident, but when I decelerated and put it into second to turn into my street, it started happening again. I made it to a parking spot and there it sits. I started it last night and it idled fine but I haven't driven it yet.
I thought maybe my clutch was finally going, but that wouldn't explain why it ran so poorly. Would one loose plug wire cause such an issue? That's all I can think of as to why it started back up and ran more or less fine. I checked the IAC last night (it's only a couple years old) to see if it was dirty and it looks ok. When I unplug it when the truck is running, it dies immediately indicating that it's working I guess.
Any ideas? I'm lucky that I can cycle/walk to work, but I need to figure this out before the weather turns...
Thanks.
Thanks.
