2/4 drop?
Check out my vendor forum here for a list of links to all the ibeam ranger lower parts you could ever need http://therangerstation.com/forums/showthread.php?t=56199 also nobody makes a 3" drop coil for ibeam rangers it would be extremely hard to realign.
I turned my OEM coils into 3" drop coils, but I have machinist experience & wouldn't advise anybody to do it....
Also, with the 4 degree adjustable camber bushings.....I was able to align it myself using the Tech Library procedure....take a look at the '36 Ranger...it's a 3/5 inch drop, but most people want me to raise the back bumper a little...it does look like it's carrying a load as is.
At 2/4 your fenders will be the same distance from the ground. But if you look at your truck from far away, you will be able to tell the front is higher. I was dropped 2/4 for about 10 months. The only problems with 2" or 3" springs will be the caster. Mine pulled to the right, but I didnt have any tire wear issues.
Let me know how they work out when you get them.....send me a P.M. (personal message)............
will do i will be geting my set next pay day 15
