- Feb 17, 2010
- Manual
Hey all,
I recently picked up 1986 2.3L Ranger with a 2 inch body lift on 29 inch tires. Shes is fine for cruising around up until you enter highway speeds (55mph+) where you effectively loose all power. You have to run it at 3000 rpm to maintain 65mph and need at least 3200 rpm to get up even moderate hills at speed. My vacuum gauge reads 5 In/Hg or less, and my mileage takes a huge hit (duh). I spend a lot of time on the highway with the petal floored, constantly down shifting, and the revs way higher than I like to see them.
My question is whether or not (and how?) to switch the gear ratios? I spent $1100 on the truck, no rust and allegedly 100,000 on it it. I don't want to spend a fortune but would like to get something that could cruise at 65mph and still have pick up at around 2500. How do you determine the proper ratio? How much can I expect to spend DIY? How difficult is it? Is it even worth it? I have to run it pretty hard, especially in Vermont and have a lot of trouble keeping up with traffic through the mountains....
Thanks
Thanks
