- Jun 1, 2001
- Age
- 64
- 1987... sorta
Do you really believe that the turbocoupe clutch is bigger?
It isn't.
The Merkur turbo clutches are exactly the same diameter and spline
as the ranger clutch.
the T-bird turbo clutch only has a different spline on the disc.
the pressure plate may be have a weaker diaphram in the ranger,
but that's EASILY corrected by using a 2.9 pressure plate.
Frankly if I were actually actively building a turbo ranger I'd definatly build
it with a Mazda and I'd put a centerforce clutch on it,
one spec'd for a 2.9.
I frankly won't build a turbo ranger in a 2wd so 4x4 is an absolute necissity
and I prefer parts that are easily aquired.
After much thought I want to put a gen1 cab onto a Gen4 rolling frame,
because I've half decided to make the thing AWD rather than 4x4.
I believe the '98-up 4x4 stuff is better for "ON highway" use anyway.
and bigger brakes is always a plus.
AD
It isn't.
AD
