2.3 turbo swap doesnt run right
thanks
it would be easyer if i could use the tc ecm. but on the drive side fo the motor that square plug in the main wiring.( gos in the fire wall) how would i wire in the tc wiring to my mazda/ ranger??? thats one prom. .................... and i have the coil pack block. i 0would neeed to swicth blocks. im looking for a easy way out lol
you should of left the 8 plug head on they flow better than a 4 plug
the ports and cam looked way bigger than the stock ranger head. thats why i did that
go to jcwracing.com get ahold of them, they can help you tune your stock ecu. you're going to need injectors and a bigger MAF at least. they can help you get everything tuned.
probably 2-300 more for parts and i don't know what the tuner will run you probably another 250 so about 5-600 more i'd say and you'll be all set up.
