2.3 to 2.9
ya the map sensor is a little important.
codes can be pulled with just a jumper and a test light (the check engine light probably isnt hooked up, if any of the rest of the itnall is anything to go by). more details in the tech library.
Well I tried to pull the codes but it wont do anything i connected a test light then connected the jump wire but it didn't do anything no flashes or anything. I had the key on and the engine off but didn't get anything out of it. I did notice that it runs almost perfect for the first minute or so then it acts like it is missing real bad and when you give it some throttle it wont rev up past about 2500 and it sounds like it is backfiring through the intake. possibly the timing is off?
you had the ignition off while hooking the jumper up, right? you should at least get a code 11 (test passed).
timing is a possibility...the pcm does advance the timing as the engine warms up.
that and the ingition module right? i'm not sure what the failure modes are though
2X- have you hooked up a timing light and pulled the pill to see if its at 10 degrees?
what about disconnecting the map sensor to see if it goes away again?on post 12 it sounds like it started when you plugged it back in.i'm don't know the procedures offhand but you really should check the values of all your sensors,maybe the map is bad?
I got it to give me the codes and it showed a 54 for a IAT high signal and a 67, must have been a 2.9 auto computer
is the IAT present and hooked up? if it is, you can unhook it and see if your problem is still there.
