2.3 fuel problem
dngrrngr07
1992 Ranger
i have a 93 tempo with the 2.3 in it. it was going to be a derby car so i dropped the tank out of it. i put my own tank in and fuel pump in. i tried to start and nothin. its got spark and its getting fuel through the fuel rail to the injectors, but theres not any fuel gettin shot into the cylinder. anyone have an idea. let me know, (the fuel pump cutout isnt tripped)
They have available at O'reilly Auto Parts the "nodes" that plug into the fuel injector harness to see if you are receiving a signal at the injector. You can rent them with a full refund when you return them. I would try that once and see what you are getting. If youre not getting that signal you need to start tracing from there and check all fuses/relays and wired to make sure they are not corroded or anything out of the norm.
