no the guy i got it from bought it and it wasnt runnin i put a new fuel pump egr position sensor and plugs he put a new timin belt injectors tps and iac on it and i also put a map sensor on it
you might have to check the timeing on the timeing belt. put piston 1 at tdc on compression stroke and check on the timng belt pullies to see if the dot on the crank and cam pullies are lined up good luck
