- Aug 30, 2007
- Age
- 45
- Manual
I just recently rebuilt the 2.3 in my 86 ranger and since I installed it on Monday, and got it running its performance has progressively gotten worse. I had the machine shop change the cam while they were in there with one they said was a couple steps above stock. So now right off start up it runs nice and smooth, but after about 30-60 seconds it begins to get worse. Some times it will get better and idle fine sometimes it get will get so bad it stalls. Now I have completely blocked off the EGR valve because it had a vac leak in the diaphram and most of it was not hooked up anyway. Also sometimes it seems as if the timimg shifts around I know that unless the distributor loose or the belt jumps around it should not move, but can some of the electronics cause this?
So here is my question: What simple thing am I missing? I'm a big truck deisel tech so I don't mess with gas engines to much anymore.
Any information you guys might have would be greatly appreciated.
Thanks
Thanks
