2.3 ecoBoost 4x4 M/T Shopping list
No, no... they have to design a new engine separator plate and a special starter too, better make the trans a different length so we can fuss over different driveshafts... because Ford has to Ford.
Nissan builds manuals, Toyota builds manuals, if Jeep doesn't I bet they soon will... there must be something of a market there.
Jeep puts a manual in the Wrangler (JL). Haven't checked the Gladiator, but it would be absolutely nothing to put one in, since most likely it is the same drivetrain already in the Wrangler.
Funny you mention that... I tried doing that a couple times in my old '00 Silverado and it wouldn't start. There was a light on the dash, Theft maybe? That would blink and nothing else would happen. Could be tuned out of the ECM I'm sure... But the point is... The bastards even took away my push start. I'd be curious if other late model manual trans vehicles do that... That truck is 20 years old now!
A '18 Tacoma can be push-started... Not sure about others (a friend has a '19 Mustang with the manual, he won't even try because he thinks he'll damage something because it's leased lmfao).
Well I would say that 85-90% of drivers can't drive a manual or do not want to drive a manual, likely higher
Matches exactly with my earlier statement that 10-15% of people do want a manual. If car companies hadn't been restricting their availability, I bet it would've remained significantly higher, maybe around 20-30%.
Toyota charges more for an automatic truck than a manual, everything else being the same (about $1400 IIRC). I imagine it's similar with Nissan (PJ might be able to confirm).
The only glitch is the Gladiator is pretty stout for payload/towing while the Wrangler is kind of a wimp. There might be durability concerns just dropping a JL trans in a Gladiator.
Part of the limitations for the Wrangle is their light weight and short wheel base. There is more to it than that but there is a point where their small size is a penalty instead of a benefit.
My FIL had a Wrangler, that extra long two door they used to make. Electronic clutch, you couldn’t push start it. He hated it.
I went to the Jeep website. It infact does show a manual trans available for the Gladiator (auto is +$2000).
Ok, I didn’t think they were available out of the gate, I may have my wires crossed with the diesel though.
Looks like we bought the wrong trucks, and are on the wrong forum if we want manuals, :)
If I was going for the manual, I would have bought a different brand of truck. Unfortunately, circumstances in my case required I get something with a slush box. I almost went for a Tacoma then the new Ranger came out.
Nope, the three levers coming thru my floor are not for decoration.
I thought this was a pre-2004 Ranger build?
2004 was when the instrument clusters changed to HEC and were married to the ECMs, also got SJB(smart junction box), which adds a few extra layers of electrical issues
I think the stand alone EFI would make more sense
The Mustang ECM will have the same issues of being married to the cluster, would need lobotomy plus make it a quadriplegic if it does have traction control software
1995-2003 Ranger has GEM module which is autonomous, and analog cluster
1995-2000 it did control 4WD but if you high jack the 4WD dash lights for the manual transfer case it won't care
2001-2003 GEM didn't do 4WD
If you get a 1997 or older manual transfer case you can use a gear driven VSS on it, for the 8,000ppm needed by speedo, and EFI system, 8,000ppm is the Ford standard pulse per mile
And it can be adjusted for tire size and axle ratios by swapping gears
EDIT:
And haven't looked it up but is the 2.3l Ecoboost a "drive by wire"?
No throttle cable, just adds some cost to a stand alone setup if it is
The 2.3L Ecoboost is a drive-by-wire engine. I'm planning my own potential Ecoboost swap for my 1997 in a few years. I'm working on the analog gauge cluster issue right. Designing a converter box that will plug into a Ford Performance wiring harness' OBDII port and make everything in the factory dash correct. Still in the process of reverse engineering and prototyping. I'm an electrical and mechanical engineer, so this is my hobby right now. After reading your post, I'm glad I have a 2WD manual truck. It'll make things easier.
There's emulation and deletion for this for the last four years I know of. People just don't post here. Couple 2.7 in old cars down south.
Nice to know your working on gauge conversion. Quite a few setups i have seen using pi and fs...very impressive.
Using the dash from the donor doesn't bother me. Once my wife's kitchen is done my plan was going to a 2.0 or 2.3 in my bll ...
But the cyclones really have my attention.
Since I already have the stuff for the 4 cylinder transmission in both auto and manual for 4wd ....I have to say a 600 dollar junkyard escape or edge ecoboost engine will likely get the nod first. Then a cyclone after I figure out the 4 whiZZER.
Your hobby is awesome for those interested in this 👍. Thanks for posting.
Didn't even realize this thread was here....
Damn monkeys.
Anybody know what flywheel and clutch to run on the ecoboost/m5r1 combo? I have a 2.3 ecoboost out of a 2020 explorer and the trans and manual transfer case ready to go.
I have a question for you, how many bolts on the crankshaft?
