1998 Ford Ranger P0171 code runs rough
Ellensburg wa
Hi, just wanted to get some thoughts on what this issue could be.
I'm working on replacing the intake gaskets (and fuel rail gaskets) on my 98 ranger 4.0.
This truck has 205,000 miles and the dreaded p0171 code also runs rough. Done wasting money at the dealer so I ran a smoke test and I found an air leak coming from the upper intake gaskets.
So I started disassembling, pulled the upper intake off and found what looks like oil and coolant mix in the passages.
Any idea on what this could be? I ordered lower intake gaskets as well so hopefully i don't have to go as far as to order head gaskets 🤞
I haven't noticed any coolant mixed with the oil in the pan.
  • 1998 Ford Ranger P0171 code runs rough
Probably just some condensation. I doubt it's coolant. I did this same upper intake gasket change at about 150k. I'm at 225k now and no issues since. Only did the upper plenum gaskets.
So when you did this did your new plenum gaskets have the rubber bead on both sides? Just curious because the ones I just removed from the fuel rail spacer have the bead on just one side. As shown in pic.
I used Mahle from rockauto. Pretty sure they were beaded on both sides but it was 12 years ago.
They were double sided gaskets that eliminated the air leak, but unfortunately it still runs like crap. Before I did this the dealer replaced dpfe sensor, o2 sensor closer to exhaust manifolds, the maf, egr. When I got the truck back from them it ran good, but when I'd go to start it in the morning it would run rough for a few seconds then correct itself and run good.
After a couple days it wouldn't correct idle and continues to runs rough. Still has P0171 code
Fuel pressure is at 61 psi when running at idle and holds pressure.
I'm at a loss the only thing I can think of is fuel injectors and lower intake gasket. 🤷‍♂️
Any ideas??
