- Jan 5, 2009
- Automatic
HI
My borther has a 1997 fleetside single cab 4.0 automatic ranger that I am going to be inheriting due to wrecking my 99 dakota. His truck is lowered in the front with airbags and in the back with blocks. It appears to not have spring cups on the front, top or bottom. What can I do to either
a. make the truck not bounce like a basketball
b. put springs and a stock suspension under the front.
c. at least stop the airbags from leaking.
The airbags are new I am pretty sure (99%) that the air lines are the problem. We put a barbed fitting(with hose clamp) in the top of each and ran an airline to a "T" (with hose clamp) with a schrader valve, so they are technically hooked together. I am not really sure what is supposed to be there. I am thinkin of putting a fitting in the top of each one seperately and filling them to the desired level and leave them alone. Is that the best way to go?
