- Jan 3, 2009
- In the Middle
- Manual
1997 2.3 with a manual trans.
I've been getting a P0303 and a P1443 code.
The engine idles high, usually about 900 to 1,000 rpm.
If I accelerate at a slow rate and don't use much throttle, the engine will run pretty good.
If I use more than just a little throttle when accelerating, or rev the engine while sitting still, the engine will start to miss real bad. The "miss" goes away after just a few minutes... until the next time the engine is revved. The "miss" happens at a lot lower rpm when the engine is still cold (but in closed loop).
What am I dealing with here?
